I do digital printing but have an opportunity to get high quality/detail black and white print work. What kinds of presses make the most detailed prints? Can a small replicator do the same as a larger B3 or B2 sized offset press? I know that the new DI presses advertise up to 300lpi, what resolution can the older or simpler machines produce. I am very new to offset as you can see, but just wondering how do you compare one machine against another when speed or color printing is not an issue, and you just want the most crisp/sharp image possible. Thank you. Robert
You might want to get a better understanding of vision and reproduction.
For example which of these two images has the most detail?
Technically it's the one on the left even though the one on the right appears to have more detail. The perception of "detail" is typically related to short range contrast changes as that's how our eye/brains work to register detail (Mach Bands).
So, for black and white work the printer that can print the darkest black has (with some appropriate image processing) the potential to achieve the greatest contrast and hence the best appearance of detail. Resolving actual detail in presswork would be a function of the halftone screening used. The higher the effective lpi the finer the detail that can be resolved. So, in that context, 10 micron FM, would be best followed by 20 micron FM, then 300 lpi, 240 lpi, 175 lpi etc.
