Canon C6010 Adjust Gloss Level
CBSprinter
Is there a way to adjust the gloss level on a Canon C6010 color imagepress? I'm running a pressure sensitive polyester clear substrate 12 x 18 GSM 210. Thanks.
Tell the machine it's 80# text, or anything under 150gsm. It will only use the primary fuser and tone down that gloss.
There's also a setting in the advanced paper settings called" Gloss and fine black adjustment", but I've never had any actual success with it.
You can adjust the Gloss and Fine black adjustment in the paper type management settings. It is most noticeably on heavy coverage, solids etc..
