drummerpaco
I have question on converting RGB images to CMYK.
I know that RGB color gamut is much wider than CMYK, however we like to eliminate color shifting as much as possible.
Currently we have tested that two RGB settings (Adobe RGB (1998) and sRGB) converting to CMYK (Coated GRACoL 2006) using Photoshop CS4.
The test result from Adobe RGB (1998) to CMYK (GRACoL 2006) and sRGB to CMYK (GRACoL 2006) shows different conversion.
Some of the details has been disappeared even though Adobe RGB (1998) has bigger color space, but sRGB to CMYK is still has the original details.
By searching many color management forum, we found many of professionals uses Adobe RGB (1998) convert to CMYK color space which by the test, we found sRGB is better solution.
What is your thoughts and suggestion for converting CMYK o RGB?
Also should we use 1)relative colormetric or 2)perceptual?
