Re: Editing DeviceN images Acrobat
> {quote:title=Lukas Engqvit wrote:}{quote}
> Sorry? How did you come to that conclusion? The first post explains that that is not what he has. Are you saying that IF the source was only a PSD then it would be a five chanel file?
I am saying that a DeviceN image in a PDF is a single image with N channels - that's how DeviceN works.
As far as verifying this particular issue, I opened up a PDF in Acrobat 9 Pro Extended on Windows XP (on the same box as Photoshop CS3 Extended) that I have containing a Hexachrome DeviceN, which consisted of 6 channels. I then used Touchup Image to try to edit the image and received the error message as noted.
> If so I can't do it. I just tested it created a CMYK file added and extra spot channel created a square on the extra channel and exported to PDF. I get a CMYK image and channel number 5 as a seperate image in the PDF, exactly as described. Not wanting to be obstinate, but where do you get your facts, I can only get them from experience.
It appears that Photoshop is not able to create a single DeviceN image from a CMYK+Spot channel image. (I tried and got the same result you did). I also tried switching to multichannel mode (from CMYK) and then Photoshop wouldn't even bother to offer PDF as an output option. And neither InDesign nor Illustrator can import the multichannel image either
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Time for a chat with the folks over in Creative Suite!
> > Second - Acrobat simply writes the image out to disk and then sends it over to the image editor. Photoshop, in this case, is reporting its inability to edit the content. Why, I don't know.
> Are you confusing this with another thread discussing index images that could not be edited?
No - see above...
> > Third - I am not aware of any way to edit a DeviceN image with Acrobat + Photoshop at this time.
> I was assuming a typo that it was Device CMYK, since there is no such thing as DeviceN CMYK.
While there is nothing called "DeviceN CMYK" in the PDF Reference, the fact is that you can have (and it's not uncommon) a DeviceN with N==4, where the channels are specifically named Cyan, Magenta, Yellow and Black. According to the PDF Reference, and the PDF/X standards, such a color is to be treated EXACTLY as DeviceCMYK.
Leonard
