agsa
I have two machine, nuvera 120 copier system, and other nuvera120 production system, the technician installed the software to the two machines.
but the two machines required to set the correct toner, and I've put different toner (I bought them in the US). I that does not happen, and also tells me there jammed paper between the areas 1-7 and I changed the sensors from one machine to another, also the card and nothing,
You could help me?
I pass the list of errors each.
PEM 09-9004 (TONER)
PEM 09-9011 (TONER INK )
PEM 09-9014 (TONER INK LOWER)
PEM 09-9000 PRINT ENGINE JAM
You could help me?
PEM 09-9004 (TONER)
