Felix Brunner Items-
danremaley
I have attached several articles by Felix Brunner, they are valuable to anyone trying to understand Color Lithography.
You can contact me with any questions 412.889.7643 Dan.
  • Brunner pg 8175.pdf
  • Brunner11x17.pdf
  • Brunnercolorimetry.pdf
  • BrunnerDens.pdf
  • BrunnerHex.pdf
  • BrunnerPictureClass1.pdf
  • PCReference.pdf
Hello Dan,
Greetings, Would gladly be appreciated if you could share the Felix Brunner ( Handbook of Print Reproduction) English version
Sorry, I don't have that Brunner book. Contact me off line I have one that's better!
  • Printing to Gray Balance.pdf
Gentlemen and fellowLithograpers,
With great respect for Mr. Dan. Remaley also Felix Brunner and their many articles about "Grey Balance"
I suggest you read Gordos PrintBlog article entitled "Grey Balance Unbalanced-An inconvenient truth"
Regards, Alois
Here's an item I wrote several years ago and the responses.
The standard deviation of a press is + or - 2%. That 4% variance in any particular color will show a cast but if you keep the colors in 'balance' the 4% variance becomes only a 'light' or 'dark' variance - this difference we can live with. (see PCReference).
Here's an idea I always wanted to try- take your 50-40-40 patch into Photoshop and set for Medium GCR - these new values can be placed in the color bar. Now the grey patch won't "change" until the standard deviation happens (+/- 2%)... Of course you need to apply same amount of GCR to the images & tint builds at rip level.
Attached is a pic of the ALL color readings on a X-rite 530. When the C-M-Y is within .03 of each other = Grey.
Certainly none of this matters printing a Red fire Truck or saturated pictures. . .but it won't hurt them either! I don't buy the "in line" argument - the separations have the correct size dots for a 'correctly' printed sheet - if not - go back to pre-press and adjust the dot size! You can't "color correct" at press you can only color ruin!!
I managed a color trade house in Pittsburgh making separations/proofs for printers.
All the best!
Article-1
Article-2
  • PCReference.pdf
