eran
I recently identified an issue with my 7880 in which it's two color red and magenta were far from achieving ISO spec. Prior to this instance, I've not really had to delve into Colorproof or the MX4 that was set up by my predecessor.
Needless to say, I've been learning an endless amount about my software but I've run into one problem that I cant seem to get around... to make matters worse, It seems to be the root of my red issue.
I found an earlier post that seemed very similar and the problem ended up being a faulty measuring device. Taking that into consideration, I've attempted using my i1 instead of my beloved Isis only to find the same results.
Most of my profile achieves acceptable deltaE; the only exception being the colors that rely heavily on magenta.
Any ideas of where I might be going wrong?
Could this be a device failure of some sort?
