NorwoodPress
So I've got a 3 part ncr that is black & white, double sided and is numbered. I get 2 up on a sheet as it's A4 on SRA3 sheet. I'm pulling from tray 5 for white top sheet, tray 6 yellow middle sheet and tray 7 pink bottom sheet. So there would be 1,875 sheets per each coloured sheet. Totalling 5,625 sheets. The fiery estimates around 2 hours for this. When I run the job it seems to run slower than when I do a normal ncr. All the ncr paper is set the same in the media library, same fuser temp, paper weight etc. I have ran a 2 part ncr before double sided and it flys through. Not sure why its taking so long to print.
