page size in preflight
2mira
when i checked page size using pitstop preflight
I Identifies the page size with (210mm width - 300mm hight ) ..........for Example )
if there is page size (211mm or 209mm) (difference with 1mm more or less than the Specified size in the pdf file )
the preflight report shows no errors
I need to know the reason and if 1mm constitute problem or not ?
No Title
The check has a tolerance which you can configure (it's the 'precision value'. The reason its needed is because not all applications describe page sizes exactly, there are normally some rounding issues that need to be taken into account.
You can reduce that tolerance if you wish to make the check scricter.
No Title
This is how page size appear on my device
No Title
Ahh you have an older version that does not have the tolerance in the Preflight Report.
You can still get the same functionality by using an Action List to get the same functionality. You can then add that Action List to your preflight profile.
