Prinergy Administrator Connection Problem
ruvinath
Hi thr,
How you guys doing , hope you guys fine,
i got some problems with my prinergy administrator, it shows my connection with server always unavailable, i tried both file transfer protocol (HTTP) (windows Server) but still it cant enable, pls help.
OK it looks like Prinergy 5 so I am going to try and remember. Do a screen capture on all the settings pertaining to that press conection. Then simply delete it and add a new press. Be sure you have the correct IP address of the press before proceeding.
the 192.xxx.x.x address is an internal IP address so I doubt the protocol will be http. I think when adding a new press it should give you an oppurtunity to click on it from a list of all available on your internal network.
can you pls help me thru team viewer,
