Remove CMYK icc tags in a PDF
Hi Magnus, try the attached .eal:
Select by ICC tag subtype (ICC tagged RGB, all three checkboxes)
NOT
Remove ICC Tag (both checkboxes)
In other words, select everything tagged with an ICC profile, except RGB - then remove profile.
This will also strip ICC grayscale profiles, so be careful, one would have to add an OR operator and selection in there to bypass any grayscale ICC tagged elements.
NOTE: CMYK profiles are still retained for blending spaces, not sure if this is OK or not?
  • Remove CMYK ICC Profiles from CMYK.eal.zip
Thank you Stephen! I think that will do it!
I need to grasp around this NOT option any day soon :)
I think of the NOT logical operator as simply an inverse/opposite/exclusion modifier to a previous selection.
More from Enfocus below:
________
AND is a logical operator. This means it is used to select a single object with more than one attribute. For example, selecting text that was Helvetica AND size 12 pt would be written:
Select Font Helvetica
Select Text if PointSize = 12.00 pt
AND
You do NOT use AND to select two different objects. For example, the following is incorrect because a font cannot be both Helvetica and Arial:
Select Font Arial
AND
________
NOT is a logical operator. It is used to exclude objects according to their attributes. For example, if you wanted to select all the text in a document that was not Arial you would need to exclude Arial from your selection. This could be written as folows:
Select Text
Select Font Arial
NOT
NOT only applies to the immediately preceeding item in the list of selections
________
OR is a logical operator. It is used to select objects that share attributes. For example, selecting all text that is either Helvetica OR Arial would be written:
Select Font Arial
OR
You do NOT use OR to exclude objects. For example, the following will not only choose 14pt fonts if there are no 12pt fonts. Rather it will select all 12pt and 14pt fonts:
Select Text if PointSize = 14.00 pt
OR
________
If you want to select times Roman and Times roman Italic, you have to use 'OR'. Not 'AND'; as they can't be both. But you could use AND if you were looking for Times New Roman which was also 100C fill. They can be both, in that instance,
'NOT' can only apply to one item.
'AND' and 'OR' can apply to 1 or 2 preceding items, but not 3 or more.
The operators apply to preceding items, not following items.
________
This is one area where Pitstop needs improvement, IMO. Stephen did an excellent job explaining it, but unless you write new actions every day it's very confusing and counter-intuitive.
Check out the free monthly PitStop workshops we are doing online. We covered Action Lists in the last two sessions.
I agree we can definitely make the process a bit simpler, but we are seeing more people using them and spending the time to understand them so that's great.
Try this. I select all ICC profiles that are CMYK, then remove them. That leaves behind all profiles that are NOT CMYK.
  • remove CMYK icc profiles.zip
Thanks Matt, I tried to simply select CMYK ICC to begin with, however RGB were also removed.
I see that you have two separate select by ICC commands, one explicitly for fills, the other for strokes. I did not do this and I think that this is why my action did not work as intended and I went with a more complex select RGB/Not approach, which was less than ideal.
Thanks for sharing! Now I have to keep in mind not to include both fills/strokes in the same selection as that appears to have problems.
OK, I can see where I originally went wrong.
The “Select by ICC tag subtype” command is very specific in how it operates, depending on which checkboxes are ticked.
This is why Matt used two different combinations of this command with an OR operator, rather than a single command with all options ticked (which would only select objects with both fills and strokes only).
