Ricoh C9100 - Service Tech from SF BAY area needed-Ricoh Pro C9110 branded as Heidelberg CP Error"Check Printer Cable Connections"
Ricoh J
Hi Guys,
If you know any Ricoh technicians from the SF BAY area please share contact information.
we have exactly the same problem like member tpmar .
we buy a used Ricoh Pro C9110 branded as Heidelberg CP getting error "Check Printer Cable Connections".it had the Prinect RIP but we changed it to
E-83 Fiery So of course we checked all cables, need help
i'm a retired KM tech but running out of ideas on this Ricoh.
question do we need a license even when using Fiery instead of Prinect?
There is communication between the Fiery and press, when I try to print a job is shows up on the press screen,
the blue light on the press never comes on and it doesn't print. The press can print because we were able to print the counter sheet.
we have exactly the same problem on C9110 and E-83 Fiery
wondering if anyone have the extra parts that we can buy from you.
we need the 2 black data communication cables and circuit board that the cables plug into at the Fiery PN number 45112
thanks
johan
