"Warning" warning? [Z6100ps]
eran
I'm running into an error on the OSD while spooling a relatively large file which says nothing but "Warning" ...
In some cases, the job proceeds to print fine and in others it will result in large amounts of wasted paper followed by a small postcript error (see insanely irritating image below...)
:confused: Anyone else encountered this?
Looks like you print driver is generating a post error and printing it out, there should be a setting in the driver to turn off printing or outputting the error,
from the manual
The output is completely blank
If the front-panel graphic language setting is Automatic (the default), try the other settings: PostScript for
a PostScript file, HP-GL/2 for an HP-GL/2 file, etc. Then send the file again.
When you have finished this particular print, remember to reset the graphic language to Automatic.
