Screen 8000II error code
Pressmanscooter
Greetings all! I've been getting this error randomly. E4e01: Excessive current in the LD drive (driver 1 board).
Anyone have this issue? What was the cause/remedy? All help welcome!
Scott
Scott
If error go off and return probleby bad laser if no bad laser drive board prepare power supply 5v 60 amp also in case
There may be several reasons for this error...
Laser drive board #1, most likely faulty. To complete the diagnosis, you can swap boards (for example, #1 and #3 boards, AND ITS CURRENTS, please see att. photo). If after such swap, the CTP starts to show an error E4e03: Excessive current in the LD drive (driver 3 board). - then it's definitely a faulty board.
Hope this helps you diagnose!
Good luck!
ExChange Ld driver 1-3 first, if errod goes to anoder ld slot must rapair driver or buy new
If stay the same slot :
Check ld dioda, not all together, separately. If all steps not fix this up voltage 5v
my company rapair ld driver for 300euro.
