Acrobat X help
oxburger
Can anyone explain why this keeps popping up when trying to open a pdf? and more importantly, how to make it stop?
I've never seen that one. There are some things Acrobat does routinely but doesn't tell you about unless they take a long time. I would try disabling javascript in case document-level or application-level code is doing something (javascript can present those progress bars). If that doesn't stop it, I would suspect it to be an Acrobat function that takes a long time on that PDF (unless it happens with all PDFs).
Does this happen with every PDF file or just one or a limited selection of PDF files?
If only one or a limited selection, could you please post a sample that we can examine. This is obviously not normal behaviour!
- Dov
I'm using XI and have seen this on a few PDF files. I just let it finish.
I take it this is happening on every PDF you open?
pd
It also does "retrieving traps" and "trap zones". It's not noticeable on small files, but when I generate 5,000 to 10,000 page pdfs, it really slows down.
