brisque down can anyone help pls
K
kala
Guest
Hi
I have brisque Aix version AIX 4.3
When i start login after type cdesci it gets loginto common desktop environment after that it shows
Action Required:
The DT messaging system could not be started to correct the problem
1. Choose (ok) to return to the login screen.
2. Select fail safe sesssion from the login screen's option menu and log in.
3. Check to see that the hostname is correct in :/etc/hosts.
other hostname problem can be corrected by using the command smitmktcpip.
For additional information pls see the DT users guide.
if i click ok then only brisque startup with continue lodon.
Kindly suugest how to sort out the issue.
rgds
kala
Hi
Action Required:
rgds
kala
Kala,
I think that it must be something to do with some of the settings. i.e. TCPIP settings; hosts settings. etc
Kala
At a guess I would say that you changed the IP Address for the Brisque within the CDE and now you have two entries within the host file. One with the old IP Address and One with the new.
Dear All
Problem sorted out by removing all the hosts and reentered tcpip ; now everything is working ok...
Dear All
Well done. Remember what you did so you will be able to solve the problem next time.
