Colror Correction for Acrobat
damfino
Is there a plug-in for Acrobat 9 which might afford some measure of PDF color correction? Contrast and brightness, and/or saturation and hue?
Thanks!
Yes there is a pluggin called photoshop ;)
If you use the editing selection tool, you can right click the image and touch-up image in photoshop. Note that some images are split into several tiles, these are much more difficult to edit with consistent results, but if you touch them up using photoshop with eg curves, when you edit the next tile you need to hold down alt/option when you choose the same adjustment and it will used the settings you last used .
The Obvious
The Obvious
OK...guess I was asking for it! I own CS4, no less.
Was looking for something quick and dirty within Acrobat.
Thanks - will try.
