Re: 200 line screen with film
Whether you need to up the resolution on your filmsetter to go to 200 lpi will depend on the halftone screening system being used. Screening that uses supercell technology (most modern screens) will not need the extra resolution.
You will need to apply a dot gain compensation curve though. If you are using the film to also image your proofs you may get a disconnect between proof and presswork caused by the curved film being appropriate for plating but no longer for proofer.
You may also have to increase draw down times in the vacuum frame. Check the consistency of plate imaging in your vacuum frame using film with screen tint patches of at least 1, 2, 3, 4, 5% and 95, 96, 97, 98, 99 and 100% placed at each corner and centers of the film.
best, gordo
