4Press Error: STB Calcualtion Error
onevon2k
hi
good day. got an error on my dolev 4press V imagesetter. Upon sending file to print via PSM 7, this error occurred:
STB Calculation error.
My suspect is the STROBE 7 board. and also i tried to run TEST PATTERN via service utilities, but i got the same error. it also says strobe error...
please help.
my board config are as follows: SOMC - ACRI - STROBE 7.
best regards,
Jonjon
ok you have two options my friend
take out the Strobe 7 board and with extreme care take out the Xilings (or CPU chips) you can. for a few seconds 20 to 30, then put them back and put back the Board.
if it doesnt fix it, then you are complete right the board is broken. and youll need to get a new one.
ok. but is it removable(xilings). ill try to take a look at that and try to remove. bec i even tried installing FAST STROBE 5, but it does not work. i think its not compatible since it enters REMOTE MODE upon sending job from PSM RIP.
Anyway, thanks. for your reply.
