Hello,
We're looking into running some tests at a lower lpi, and I was curious as to the easiest way to adjust this. I believe we're running everything at 150 lpi right now (Is there a way to check?) with a Staccato screen.
We run newsprint for the most part, and looking around online a 150 lpi screen seems to be high. I'm assuming that dropping the lpi significantly will require a new curve. The goal is to make printing a bit easier when setting ink and registering.
I found an option to override the lpi when printing an imposition into a job, but haven't found any settings other than this. Making a change to a process template would probably be easiest if possible.
