we start a job, and check the strip to the blanket,4-5mm. after we run about 8 thousand sheets, it starts to break up in the middle. and the strips on the end are about 8mm and the middle is the same. the press is a 56 inch mitz with a harris bruno coater. the cylinders have a good strip to each other
