Color Management Software and Leopard Compatibility
Bill W
Greetings,
Would like to upgrade to Leopard but also need to keep using:
Tool Crib
Profilemaker Pro 5.0.8
ColorLab
PatchTool
ColorThink
IDEALink Curve
Xrite Diagnostics tools for eyeOne and iO
Web searches indicate that the following ought to work:
Profilemaker
PatchTool
ColorThink
IDEALink Curve
I can find no confirmations that these will work:
ToolCrib (posting on Xrite site indicated it will not work)
ColorLab
Appreciate feedback on success of using these apps on Leopard.
Thanks.
-Bill-
Did you find that Colorlab ever worked consistently on any os level? ;)
Ive used the i1 diagnostics (not IO if there's a difference) with leopard with no issue, but not the others. ColorThink pro pretty much replaced my need to tinker with colorlab.
I'm using the following on 10.5.6 with no problems:
Profilemaker
ColorThink Pro
IDEALink Curve
PatchTool
Greetings Mike,
Thank you for continuing to remind me that ColorThink is a great program and I can use it for many, many things.
My major concern is with ToolCrib as I use it to interface with my Xrite 528. Using the 528 I average and compare both TVI and Lab values during P2P and profile press runs.
-Bill-
-Bill-
Well, it installs and launches fine on Leopard here, but I don't have a device that connects easily to a MacBook Pro (and I really prefer to avoid messing with last centuries DTP-41 or 939 and all the connectors, adapters and cables and such just to prove a point to some guy posting on a forum board, but I didn't say that out loud). ;) You could always install Fusion, Parallels or Bootcamp and run it in Windows if for some reason it didn't work in Leopard, but it probably will.
