Counter
Andrei83
Hello, gentlemen. It is not possible to set the counter after the repair. you need to adjust the number of sheets in the bundle, but this doesn't work. The counter runs without stopping. you need to set up 200 sheets each.
Help me find the instructions and connection diagram. Thanks everyone.
Check if this applies http://www.farnell.com/datasheets/99563.pdf
Or find an electronics engineer locally to replace it with a new programmable counter like an Autonics CT series or similar. I successfully replaced an IVO counter last year on a Heidelberg offset machine with a new autonics (less than 100 US$). Took me an hour to fiddle with settings and wires, works perfectly ever since.
Thank you, I will wait until Monday can someone help and provide the scheme.
