DC-2060, error Codes 6-xxx
sachint_in
hi
my machine problem with magenta
code is 6-373, 6-374, 6-381, 6-382
i have done all initial action (Interchange ROS, Interchange Developer Module & Interchange Drum)
please help me what is the exact problem
thank you
Check black pretransfer corotron. May be it is arcing.
This can cause you those falut codes.
You can check Magenta Ros motor from DC330 006-031 does it rotate?
But Magenta Developer exhausted 2 times... why ?
Poor bias, bad ESV, bad corotron, bad TC sensor, NVM coruption. Those and many more might be the reasons for developer dumping ( if you mean this with "exhausted").
If you are giving a little bit more info it would be great.
Max setup competes successfully?
