turbotom1052
About 3 months ago we switched over from an Agfa plate we were running with no problems to a Fuji LHPI plate on our late model Mitsubishi Diamond. Since then we've experienced a myriad of problems we never had before. Some of these problems are persistent and some are intermittent issues. On the persistent front we have experienced significant problems with drying on jobs that do not aqueous coat. I attribute much of these drying issues to the increased demand for water in order to try and keep these plates running clean. I would estimate the increase in water supply to be close to a 20% increase. We tried various amounts of fountain solution and alcohol sub to no avail. Another thing that seems to be consistent is an issue with the non image area "Tinting" on all colors. This tinting of the non image area on longer runs makes for picture framing issues that require more frequent blanket and impression cylinder cleanings.
Another related but intermittent issue would be the issue of plate sensitivity. There are times when the plates (in particular the black plate which we run down first) will get all toned up if we stop the press long enough to do a blanket wash. Once the plate becomes sensitive (usually after running over 10,000 impressions) the plate must be gummed even if the press will be down for long enough to remove a stubborn hickey. It should be noted that the problems with the black plate happens regardless of what unit we print it in, so i think its safe rule out faulty roller settings or mechanical issues.
We were of the impression when we switched over that the changeover would be basically plug and play!!! It has turned out to not be the case and was hoping that some of the members could offer some help.
Below is a list of what products we are using.....
1 Fuji LHPI plates
2 Toyo hyplus ink
3 Prisco 3451 fount
4 Prisco Alkaless 3000
5 Reverse osmosis water supply
It should be noted that we've tried running various amounts of fountain solution and alkaless to a starting conductivity of 1400 up to a starting conductivity of 1900. We've also tried running our chillers at various temps between 65 to 70 farenheit.
Any input would be welcome particularly from people running Mitsubishi presses with this very same plate!!!!
When we spoke with Fuji about these issues they tried to have us believe that we are the only ones with this problem. They also suggested that we switch over to their fountain solution which i believe is Emerald. Seems like everyone wants to sell everything these days. We would love to make this plate work as its a better value but only if were not plagued with the issues we've experienced. Down time to clean blankets and impression cylinders more often is killing us and even though it often takes a loupe to see the slight tinting on the sheet it is annoying to know its there and only a matter of time before a customer notices.
1 Fuji LHPI plates
2 Toyo hyplus ink
3 Prisco 3451 fount
