Heidelberg Tango Drum Scanner
MrDHG
$1,000
Vertical Drum-Scanner
The Heidelberg Tango is specially designed for high-resolution scans.
Vertical drum scanner obtains a very good sharpness and reaches a density up to 4.2. Even in dark ares the scanner recognizes slight nuances and is able to create an optimal depth effect.
The resolution is between 100 and 11000dpi. This means that pictures can be enlarged up to 3000%
Max useful scanning area is 450 x 480 mm (17.7” x 18.9”)
Scan as RGB, LAB, or CMYK
Transmissive or Reflective Scanning
Comes with G3 Mac with software Linocolor 6.0.1 loaded
Mount Station
2 Scanning drums
Contact [email protected] for more info
