How to apply UCR settings in PrintReady Cockpit?
HarmPrep
Currently I am using the Prepare sequence to add an ICC profile to the CMYK Images called CMYK Max Density 260.icc. This works great for CMYK images, however it doesn't work for RGB. The profile that is currently in for RGB is the old AdobeRGB1998.icc. I have found that if I run a job through the Prepare sequence twice, the UCR will apply, since they are no longer RGB images. Is there a more efficient way to do this? Perhaps an RGB profile that converts to CMYK with the max density at 260 (or whatever). This problem is especially prevalent now that most of our jobs are coming in Remote Access with no control over color conversion except what the rip offers. Any input would be most appreciated!
Thanks!
I am not too well versed on cockpit, but can you change the order of the prepare sequence to have the rgb conversion first. or run two prepares one with the conversion and one with the icc
