How to change the gripper in customer preps pdf in preps or any other software
K
kala
Guest
Hi
we are getting the customer paginated pdfs with wrong gripper setting to output those files to plate we are following the below options..
1. place it in illustrator 1 page and set the gripper and replace all the other links and create ps files seperate - in this method taking more times and some time page got repeated (by mistake)
2. place the pdf in preps template with correct gripper and output...
but the problem is sometime the customer plate size is not a common size we have to trim the plate and give
normally we will place it in illustrator and set the gripper and draw a cutting lines to cut there also the same complication some times page got repeated..
if we do the same in preps by putting smart lines or ruler it shows 10 mm differ after processing the plate not in gripper side horizontal side for eg if i set a line for 710 x 950 the output will come us 710 into 960 i placed the mark as 950 in preps but after processing the marks placed in 960 ...
or anyother easiest way to put trim box for customer pdf (50 sets).. and placing pdf for correct gripper setting...
regards
kala
