ICC to presstek 34 di
Daneil
hello
wonder if there are some standard icc to presstek 34 di to use, some with toyoink, just want to test, if so , post the density value for coated/uncoated stock, thanks
Re: ICC to presstek 34 di
I think that it is not as simple as using an ICC profile to send items to the 3404 DI.
I need more info before I can give you advice...
Like What is the type of RIP that you use to send files to the DI?
Harlequin?
Xenith?
Rampage?
What Standard do you wnat to achieve? This needs to be determined if you want to have a specific Densities for each of CMYK...
US web Coated SWOP?
EURO?
Graycol - Spelling on this is not correct...
There is more after this, but was curious what you need an ICC profile for the press...
Are you pringint from Indesign to the device directly?
