gtrmke
Hi all, I need some help with xsl. I have a supplied xml file that needs some massaging via xsl before I can import it into InDesign. Reason being is there are many elements with the same name but what is unique is the name attribute.
I want to rename the element the value of the name attribute.
For the life of me I cannot get the for-each loop to work so it has been omitted from the xsl.
Below is a sample of xml...
<?xml version="1.0" encoding="utf-8"?>
<?xml-stylesheet type="text/xsl" href="source.xsl"?>
<Root>
<Data description="Data Area 1" name="Data_1">
123456</Data>
<Data description="Data Area 2" name="Data_2">
987654</Data>
</Root>
and the xsl...
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
<xslutput omit-xml-declaration="yes" />
<xsl:template match="Data">
<xsl:variable name="att1" select="@name" />
<xsl:element name="{$att1}">
<xsl:apply-templates />
</xsl:element>
</xsl:template>
</xsl:stylesheet>
I've also attached a zip file that contains the xml and xsl files.
Thanks in advance for any help
Mike
<Root>
123456</Data>
987654</Data>
</Root>
and the xsl...
</xsl:element>
</xsl:template>
</xsl:stylesheet>
Mike
