.inx font issue
a lot of clients are sending us cs3 files with the interchange .inx file.
when i use the fonts supplied and open the .inx file with my version of cs2, indy will never find any TT fonts...? any ideas why this is happening? or any idea of a solution that does not involve going back to the client?
Re: .inx font issue
No idea why this happens but I've seen it even copying from InDesign CS2 to itself in a new document. Every font is accounted for in the original document but when I copy to a new document the fonts go missing or are changed! I've seen helvetica become times and Type One become TT. Only solution I've found is to use the font finder and replace everything with what it's suppose to be manually.
Re: .inx font issue
Have you tried dropping a copy of the fonts into /User/Username/Library/Fonts, or into Adobe application's font folder (inside application folder), instead of using a font manager? Let us know how it works (if it works).
Don
Re: .inx font issue
I always place my fonts in a folder in system fonts to avoid any font management software issues, this was not working, neither was LinoType FontExplorer
/User/Username/Library/Fonts did not work
However dropping them directly into InDesign Fonts folder resolved the issue of not detecting TT fonts
WOOHOO!!! Thanks!
Re: .inx font issue
Ok I stand corrected. I had a conflict with Times.dfont so I launched FontExplorer to resolve it, unfortunately IND isn't recognizing my TT fonts again, even after cleaning all of my system/application cache and deleting any instances of those fonts in other folders. I've restarted the app, restarted the computer, retried this process and I'm not getting the same results...bizarre?
Is there any real issue with replacing a TT font with T1 font?
Re: .inx font issue
"Is there any real issue with replacing a TT font with T1 font?"
No but you may need to clean out your font caches for the font to be recognized.
