Pondicoco6
Registered Users
We bought a used IPF 8000 and used After Market ink for its test run. We used a
syringe to add ink to the cartridges that came with the plotter It ran through
all the prompts just fine.
Then when we chose the "bypass this step" option for the step that announced
that the machine couldn't recognize the ink that we were using, the ink system
went haywire and all 12 cartridges were drained
with the ink rushing into the reservoir cartridge.
We were told that after-market inks can ruin the print heads and cause
malfunctioning, but this ink came from a reputable manufacturer (Lucid). Was our
problem not injecting the ink into the cartridges that are manufactured by Lucid
and recommended for use with their inks?
If we use their recommended cartridges (with new chips, of course) do you think
that will take care of the problem?
Does initialization often use up 130 ml of ink?
Thanks,
David
Thanks,
David
