KM C1060 upgrade from KM D550
Shel
Looking for advice.
KM Bizhub Pro C1060 upgrade from KM D550
Currently running 15K per month.
This is the configuration I'm currently
looking at.
C1060
MB-504 Multi By-Pass tray unit
Es-2000 Spectrophotometer
Df-622 Reversing Automatic Document Feeder
RU-509 Relay / Buffer Pass unit
HD-514 HDD Kit (6x160GB)
Ph-102 Preview Kit
FS-612 80 Page Booklet maker Finisher
PK-512 2/3 Hole punch kit for the FS-612
IC-415 Embedded EFI Fiery image controller
30 amp surge protector
I appreciate all input!
Thanks,
Shel
15k/month is not a lot and the C1060 seems like overkill. Unless you have to run all 15k out in a single day. Or you need the kind of quality a production bizhub will give you.
Ask about the C1060L. You can configure it as above and probably save some $$.
I'd recommend you go back to the dealer who gave you the quote for this configuration and ask for a do over. The items they have listed are not a valid configuration for a C1060. It appears to me as if you have a pre-release estimate in which they substituted the C1060 in place of a C6000. Some of those items are no longer used, and other items are required. Not surprising considering that you posted this message the week before the official release.
