Ynot_UK
Our Pro951 has a PF-706 paper deck and FS-532 finisher. Printing on A3 80GSM Navigator - the same substrate we always use and run circa 80k sides each month. All new wraps opened & loaded today, from the same pallet of paper. The job is output to the main tray, with no finishing, no offsetting - just regular stacking.
Today, the machine has started outputting this sequence:
2 sheets with an upward curl just to the front of the leading edge, followed by 3 good sheets, another 2 curled, 3 good, 2 curled, 3 good, etc...
We have the substrate in trays 3 & 4 for continuous operation. This is only happening when taking substrate from Tray 3. When it is using Tray 4 the problem is not happening.
Any engine related thoughts (fuser temp, belt charge, etc.) seem to be barking up the wrong tree, as if they were causal then the problem would be seen when pulling substrate from either tray. Registration is perfect from either tray, tyres changed but the problem persists.
Any thoughts welcomed...
