motormount
Hi all,
We are running into a lot of problems trying to print stickers on KM1.
Matte paper is ok most of the times, one problem might occur if the back is ''cracked'' parallel to the the printing heads.
Glossy paper depends, no matter if the liner is cracked or not, it might print well, and it might jam as well.
Pvc is mostly problematic, sometimes prints, most of the times jams, especially after the uv lamp, the last gripper fails to ''catch'' it.
What's your experience, if you have any?
Do you print with one vendor or depending on the current material you make the right adjustments and print it?
Thanks in advance,
Thanks in advance,
