1.) When you received your Ikon Konica/Minolta CPP500 or C500 did it include updates (patches) to be calibrated for glossy toner?
1-GJDLN Server patch and profiles to be used ONLY on newer 50 PPM
engine (this engine uses new toners. It is called the "C500 bizhub"
by KM, CPP500 by IKON). This is a server side patch and a new ICC
profile set.
These show up on a print out, their are many more but this is the most important one and apparently must be installed correctly - an art it seems, probably should have been part of the original install disk and not a multistep update.
2.) Have you experienced fusing roller failures in relatively short times of under 100,000 copies?
3.) were you successful in your lawsuit or were there any class action lawsuits started?
4.) Was Ikon, Konica/Minolta or EFI found responsible?
A more complete listing of patches may be found here
http://groups.google.com/group/ColorCopier/browse_frm/thread/0dfd0e95d062d546?hl=en#
You may contact me offline
Ken (at) Communityprinters.com
Dawson Creek BC Canada
250-782-7108
profile set.
250-782-7108
