Hi i am using the beforementioned CtP for exposing waterless plates -Torray/Presstek- for GTO52 DI and want to try conventional plates without tampering with laser power at all.
I presume analog plates will not work so thermal CtP plates are needed right? Want to learn about processless too.
As far as i know the current use of laser power is increased to carve deeper in the silicon surface OR the speed of drum is reduced. Exposure time of waterless plate comes to 2-4 mins
Any ideas what will happen if i expose with same settings?
Will the CtP break/burn -gods no!-?
The plate will be over exposed and dot loss will be multplied?
Thank you in advance
