There are ways to make this much more reliable and consistent.
I will comment more on this but I have to travel now. There is a real opportunity in this area and it is not just the ITB.
Have a good weekend.
Paul,
To continue the discussion on the potential of the ink fountain related consistency and predictability issues.
There are two basic issues related to the accuracy and consistency of the ink feed into the roller train. One is the accuracy and consistency of the metering on ink onto the ink fountain roller and the second is the accuracy and consistency of the transfer of ink from the ink fountain roller to the roller train. The ITB is designed to provide a consistent ink transfer condition instead of the inconsistent ink transfer condition of the traditional ductor.
So let's look at the consistency and accuracy of the ink metering methods. There are probably hundreds of versions of the traditional proportionally variable ink key to ink fountain gap concepts that have been developed since they first were used, over 150 years ago. Alois has shown some in his PDFs but just about all the concepts used in printing are of this proportionally variable gap between the ink key and ink fountain roller.
So over the 150 years, the printing engineers have mainly refined the same idea over and over again but not really innovated away from that concept. There are exceptions in the newspaper press technology but for commercial printers, you have had the same technology for a long time.
The problem with the proportional ink metering concept is that as you get down to very low coverage, the error starts to increase proportionally. This was referred to in the last post. Part of this problem is due to the difficulty in obtaining and accurate zero set point, which is the datum for any presetting and also the minor variation in ink metering at such a small gap.
To automate a proportional ink key gap is expensive since you usually require a feedback method to confirm the actual position besides the expensive drive for the ink key, which could be a servo or stepping motor plus its controls.
There are less expensive and more accurate ways to meter ink onto an ink fountain roller. Over ten years ago, I had an idea of a binary ink fountain. One where the ink key is only in one of two positions. Open or closed. Unfortunately this idea had been already covered by a patent (US Patent # 4328748 ) by Manroland.
With this concept, the ink is metered not by proportional ink films thicknesses applied to the ink fountain roller but by a single constant ink film applied to the ink fountain roller in proportional amounts of timing. Open 5% of the time and closed 95% of the time would represent a 5% ink feed. Open 45% of the time and closed 55% of the time would represent a 45% ink feed.
The beauty of this concept is that any error in the ink metering, through the constant gap opening, is the same for high coverage or low coverage. It is also linear from 0% to 100%. A very nice mathematical relationship.
Also the drive for the binary ink key is can be very simple. An inexpensive solenoid and a relatively low cost PLC to drive on/off control to the solenoid.
Now for the good news. Fortunately the Manroland patent has expired. Their great concept can not be used with a conventional ductor because of the problem with the timing of the ductor and the on/off ink feed of the binary ink key feed. Their concept is very compatible with my ITB (US patent #6,857,366 Canadian patent #2,288,354), since the ITB will transfer basically whatever the ink metering system provides. The ITB does not care if the ink film is proportional or binary as long as the total volume of ink metered matches the requirements of the printed design in line with the ink key.
Manroland wasted a great patent because they did not think the problem through. Fortunately the potential is still alive and anyone can use it with the ITB or similar concept.
I hope that you can see that there is potential for more accurate and more consistent ink feeds that will cost a lot less than what exists now.
