Moving to New Location Sell Equip
The following is available in St Louis
Digital Presses & Laser Print Equipment
Kodak NexPress 2500 5-color- clear ink, clear red fluorescing ink, clear raise textured dimensional ink w/ ICS, Nex Station
Kodak NexGlosser
Kodak Digimaster, 6 feed trays, 3 interposer trays, hi-cap stacker & C P Bourg Saddle stitch booklet maker
Xerox iGen 3-90 four color digital press with over size sheet feed and external delivery tray, leveler enablement kits(2), CREO
OCE CS 650 cut sheet Color Laser printer
OCE PageStream 88 continuous for mono laser printer- used minimally for testing
Xerox DocuColor 250 Color Laser printer/ scanner MFP, Fiery
Xerox WorkCentre PRO128 B&W Multi- Function printer/scanner / fax
Xerox WorkCentre M1181 B&W MF network Printer
Production and Finishing Equipment
Ga-Vehren 911 cut sheet attacher
Kirk-Rudy shuttle feeder
Kirk-Rudy 8 ft conveyor
Hunkeler Snapband SBA 13 x19 continuous form affixing system
Hunkeler Snapband SBA 22 Jumbo continuous form affixing system
Hunkeler continuous form pattern cylinder gluer system
Safety Light Pole systems
Kluge WFE 13 x 19 continuous form embossing die cutting machine with heated platen
Kluge WFE 13 x 19 continuous form embossing die cutting machine with heated platen and foil stamping feeder
Moore Detacher
Robert Schmidt
Equipment Manager
706 315 6822
Hey Robert,
Hope everything goes smoothly with the office move. Just letting you know that if you have any New/unused toners sitting around, you can easily sell them at http://www.tonerconnect.net. I've used this service in the past and was pleased with the payout.
Thanks,
Cade
