The Agfa working instructions (Version 4.0) for setting up plate exposure are very unclear or we're getting bad installation set up information. Can you help?
The platesetter is an ECRM Newsmatic CtP.
The instructions state:
Exposure criteria: UGRA 1982 step2 solid (a test target film strip to be exposed on the plate)
"The :N94-VCF is correctly exposed if the step 2 inthe analogue UGRA 1982 fully solid.
That means that step 2 (UGRA) cannot be visually distinguished from the flat solid next to it."
Here's the problem instruction:
"Important: Do not rub back the machine-processed step-wedge manually for assessing the step coverage!"
What does that instruction mean? We were told to wipe the step-wedge before evaluation and that the sentence means don't rub the plate in both directions but only in the direction of the plate processor.
What is the correct procedure?
Thanks.
Thanks.
