Ph7760 false imaging module fault
This P7760 declares a false imaging unit 4 fault. This occurs immediately it is about to fully initialize and it then begins the POST all over again. I have checked all my imaging units (drum) are ok. Pls advice, thanks.
clean it
clean it
Here is what I have done. Turn the machine off and spray contacts with standard contact cleaner you can get a Frys or a hardware store.
Just like a press you need to keep the machine as clean as possible.
