Re: Prepress Interface
Rob, the way I understand it, you need both prepress interface and the direct connect kit. The direct kit is an "option". We're using the card reader/writer since the presses we're using it with don't have the latest consoles. Be careful about the older consoles, apparently PPI doesn't work "as well" (Heielberg's words) with the CPC 1.03 consoles. I didn't get that info when asking for technical and compatibility info. The PPI does seem to work as advertised, we're still in the evaluation phase though. IF you think this is going to help you, be sure you ask all the questions... two and three times if necessary.
InkPro... we have Brisque so we have to use Inkpro to create CIP3 data that the Prepress Interface then converts to a Heidelberg PPF format for the press console.
All in all, the install was fairly easy for the software. Not much to using it either. Biggest problem we had was not getting the full story on the press console.
