Refill HP 56
Vacuum clips are available in the market at very low cost. With these vacuum clips you can also clear the cartridge, clean the cartridge nozzles. You can even rebuild the entire cartridge, changing the cap top and or internal sponge materials inside the cartridge. We will have these components on our site shortly. Once you have purchased a factory cartridge you will not need to buy any more. The making of vacuum clips at home is very complicated work.
___________________________
q2612a toner cartridge
why to use clips?
why to use clips?
Wh you are so much worried about clips and all that. Have you tried compatible options for your ink? I have been using compatible ink for my printer cartridges and its working fine without any glitches !
