RE: Roland CJ-500 Problem
Hmmm, well ok then. You may have to replace the data cable (didn't see that one in your list). It's losing information in the middle of the print, I think.
Before I sold the SP-540V, it would shut down on it's own, making me turn off the main power, and re-powering up. As with all printers, if you're not going to use it for a couple days (ie weekend), I would shut it down completely. I have found the heating elements in printers kept in an ON position tend to fail quicker.
As another test, send a file via Roland VersaWorks to see if you get the same problem from the Production Mgr. It's a test that you can tell Roland techs you've done, if they come back with that question.
Good luck!! -Nikki
