Small ink jet printer similar to RISO Com Color 7150
We are trying to print on the back of 8x10 or 10 x 16 pieces of vinyl wallpaper. The surface is uneven. Ink jet seems the way to go. The wallpaper will not feed thru a laser machine. We have had limited success with the RISO Com Color 7150. Do any other manufacturers make a similar small machine?
Thank you.
Marty Kurtzman
[email protected]
MemJet has a small desktop inkjet that prints at 60 ppm. We have both the Riso ComColor 7150 and the MemJet C6010 in the shop - have had surprisingly good results with the MemJet on some traditional InkJet stocks. Best thing is it is really affordable - doesn't duplex and only handles up to legal size stock. Might be worth a try on the smaller stock.
Thank you for your response.
Do you know what is the thickest stock the machine will take?
I am awaiting a response from MemJet.
Again, Thank you.
We have run 265 gsm photo paper without any problems - not sure what the limit is on it. MemJet should be able to provide that information.
