gig0
Suppose you have to print a checkerbord and your customer wants all the red squares to have a dull varnish and all the black squares to be UV. They supply artwork that has a spot dull varnish layer along with a layer that has a spot UV. Knowing this is a registration nightmare (because the UV coat will be applied at another facility) would there be any noticeable difference if just an overall dull varnish was used with a spot UV?
I'm in that boat right now except substitute the squares with thousands of images and letters. My mind is telling me the reflective property of the UV has no bearing on quality if a dull varnish is underneath or not. Thanks.
