Technotrans error
richck
We have error code 03 coming upon our alcosmart on the technotrans, any idea what the issue is? Thanks
There are a lot of things that can go bad inside. Follow instructions in your book to clean and recalibrate. Do not open the top cover / sensor & electronics housing, nothing to see inside really. Check the mesh membrane for damage and replace if needed, not expensive. Check valve actuator at the back of unit, this regulates the ipa supply. If the alcosmart is damaged it's too expensive to repair. Best to look for a second hand tested replacement, AZR ideally.
Hi sir:
Hi sir:
Look for error 03
1) Dampening solution supply interrupted
2)Dampening solution connector Not properly connected
3)Supply pressure too low
4)Level sensor dirty
5)Lever sensor defective
Blessing
[email protected]
