XMPIE? Variable data, from a csv file.
rande
Been out of work for a couple years and I back and facing XMPIE.
I need to put 4 up post cards on a 12x18. I can't seem to be able to get the data to flow, in order, from one block to the other on the same page; then flow in order through the rest of the pages.
Anyone know? or where I can find that info fast?
It does seem to go thru Preps right either.
thanks
You need to go to dynamic print > Imposition tab. You can use step & repeat or cut and stack. Usually variable jobs are cut and stack if they are mailing presorted address. I can take some screen shots and see if they will post
okay I see that.
I tried it, got a bigger page size but only one up. I'll tried harder tomorrow but thats the right track thanks.
