Hi Chaps,
First time on this splendid forum, lots of good info.
The power supply, as above is not kicking out any power whatsoever, have checked the obvious power in, fuses etc.
I want to replace this or substitute with mix and match psu's but I have no idea what the nominal voltage rails are on the power supply.
+5V is 5V etc but the other 3 channels from the supply on TB2 are listed (on the case) as being....
Output chan 2....12-24Vdc
Output chan 3......5-15Vdc
Output chan 4......5-15Vdc.
If I am to mix and match supplies for chan's 2-4 I really need to know what the nominal voltages are when the machine is in it's quiescent state.
I would really appreciate help on this one. If anyone has the same machine and can measure them for me, it would save a lot of time and I would be able to order suitable supplies etc.
Many thanks,
Clymout.
Many thanks,
Clymout.
