Trendsetter 800II Error 35780
Adnan
Registered Users
we are facing a problem with TS800II. during production an error popup on printconsole screen and machine stop imaging " Carriage Amplifier Fault: +/-12V or 48V supply faulted or safety loop broken Prompt:43312" and after restart of machine we got "System Presence Fault: Satellite Board 24 volt presence (Sat_&24V+) Not Detected".
we have check with replace MCE board, restore firmwares and all power supplies are works ok. Please advice.
you can also review the result in serviceshall.
f 07Jun13 21:43:52.093: <MCE> MCE Power On Self-Test (POST) v1.06, Aug 29 2003 02:05:59
f 07Jun13 21:43:52.093: <MCE> Copyright (C) 2000-2003 Creo Inc. All Rights Reserved.
f 07Jun13 21:43:52.109: <MCE> MCE Board Revision:06 Configuration:00 Boot Cycles:2837
f 07Jun13 21:44:26.625: <MCE> 9010: 1M SRAM Test ................................PASSED
f 07Jun13 21:44:28.187: <MCE> 9011: 32K NonVolatile SRAM Test ...................PASSED
f 07Jun13 21:44:29.281: <MCE> 9012: Quad Uart Test A+B+C+D+......................PASSED
f 07Jun13 21:44:29.390: <MCE> 9013: 68376 Uart Test A............................PASSED
f 07Jun13 21:44:29.562: <MCE> 9014: NVS SRAM Verification .......................PASSED
f 07Jun13 21:44:31.187: <MCE> 9015: NVS Flash Verification ......................PASSED
f 07Jun13 21:44:33.234: <MCE> Search for Main Firmware
f 07Jun13 21:44:39.265: <MCE> ....................PASSED
f 07Jun13 21:44:40.593: <MCE> *** Initializing Firmware Subsystems ***
f 07Jun13 21:44:42.515: <MCE> NUC 376 MCE ERR URT MON MOP PRD MSG UTL STG FWD PRM PST LCA
f 07Jun13 21:44:45.296: <MCE> 376s MCEs ERRs URTs NUCs PRDs PSTs CAN SIF SIFSER SIO DF1 IOS BOS NET SST STA HLT
f 07Jun13 21:44:48.531: <MCE> DPC HIF CEH EHI DTL CRG RIF WMD GIM MIC MPC DRS SMC MDH MPI MDS OWB KEY IBM DEB CTP VBS
f 07Jun13 21:44:48.546: <MCE> *** Firmware Subsystems Init Complete ***
f 07Jun13 21:44:49.234: <MCE> TSMCE Firmware Diagnostic Monitor
f 07Jun13 21:44:49.250: <MCE> Version: 1.28.16 Build No: 15470 Date: Mar 17 2005 18:24:33
f 07Jun13 21:44:49.250: <MCE> Built using Baseline #3153 - Jul 08 2004
f 07Jun13 21:44:49.250: <MCE> Machine Serial Number: TM450
f 07Jun13 21:44:49.265: <MCE> BBRam Nvs Found: Addr:00C90000h Size:16384 bytes VERIFIED OK
f 07Jun13 21:44:49.281: <MCE> Flash Nvs Found: P1:00020000h P2:00040000h Size:131072 bytes VERIFIED OK
f 07Jun13 21:44:49.281: <MCE> CAN Bus Baud Rate is 500KHz.
f 07Jun13 21:44:49.296: <MCE> C ---: Using PPP Client Protocol
f 07Jun13 21:44:49.296: <MCE> *** Unsolicited Message 35733 Warning
f 07Jun13 21:44:49.312: <MCE> [Product:Front panel is open, check front panel]
f 07Jun13 21:44:49.312: <MCE> *** Unsolicited Message 45234 Warning
f 07Jun13 21:44:49.328: <MCE> [Product1:Warning: System Pressure Low]
f 07Jun13 21:44:49.328: <MCE> C MPI: Head is not ready. Media settings are not available
f 07Jun13 21:44:49.343: <MCE> *** Unsolicited Message 35733 Warning
f 07Jun13 21:44:49.343: <MCE> [Product:Front panel is open, check front panel]
f 07Jun13 21:44:49.359: <MCE> Could not configure scanning on PDB RevH or newer
f 07Jun13 21:44:49.859: <MCE> C MPI: Head initialized successfully
f 07Jun13 21:44:50.796: <MCE> *** Unsolicited Message 42901 Fatal
f 07Jun13 21:44:50.812: <MCE> [PST:No response received from Power Distribution Board]
f 07Jun13 21:44:51.468: <MCE> Version 1.93
f 07Jun13 21:44:54.234: <MCE> C PRD: Power supplies going off!
f 07Jun13 21:44:59.234: <MCE> C MPC: ABORT, status=5, file=Src\MPCCORE.c, line=2722
f 07Jun13 21:44:59.468: <MCE> *** Unsolicited Message 35733 Warning
f 07Jun13 21:44:59.468: <MCE> [Product:Front panel is open, check front panel]
f 07Jun13 21:44:59.546: <MCE> C MPC: ABORT, status=7, file=Src\MPCHEAD.c, line=7487
f 07Jun13 21:44:59.765: <MCE> *** Unsolicited Message 35780 Warning
f 07Jun13 21:44:59.781: <MCE> [Product:Carriage Presence Fault: Carriage motor presence (CM_&Motor) Not Detected]
f 07Jun13 21:44:59.796: <MCE> C MPC: ABORT, status=9, file=Src\MPCCORE.c, line=2722
f 07Jun13 21:45:00.031: <MCE> *** Unsolicited Message 35733 Warning
f 07Jun13 21:45:00.046: <MCE> [Product:Front panel is open, check front panel]
f 07Jun13 21:45:09.515: <MCE> C DPC: First SCSI connection established with work station
f 07Jun13 21:45:25.890: <MCE> C NET: PPP link is Down.
f 07Jun13 21:45:25.890: <MCE> Datalink: exposure head coming online (binary mode)
f 07Jun13 21:45:25.906: <MCE> *** Unsolicited Message 45036 Warning
f 07Jun13 21:45:25.906: <MCE> [THC2:case temperature high warning, 29 C]
f 07Jun13 21:45:49.015: <MCE> C NET: PPP link is Down.
f 07Jun13 21:45:51.484: <MCE> C NET: PPP link Up, Ip:192.168.111.102, NetMask:255.255.255.0, Gateway:192.168.111.100
f 07Jun13 21:46:03.437: <MCE> C WMD: RCON TCP/IP Server: Connection from: 192.168.111.100 to: TCP Port->5000
f 07Jun13 21:46:03.453: <MCE> C WMD: Connection established between MCE and workstation
f 07Jun13 21:46:03.453: <MCE> C WMD: Workstation Command: h=00 000Fh 'Protocol Version'
f 07Jun13 21:46:03.484: <MCE> C WMD: Workstation Command: h=00 053Ah 'Property Get'
f 07Jun13 21:46:03.562: <MCE> C WMD: Workstation Command: h=00 0018h 'Query Stat Data Types'
f 07Jun13 21:46:03.656: <MCE> C WMD: Workstation Command: h=00 0018h 'Query Stat Data Types'
f 07Jun13 21:46:03.750: <MCE> C WMD: Workstation Command: h=00 0018h 'Query Stat Data Types'
f 07Jun13 21:46:03.828: <MCE> C WMD: Workstation Command: h=00 0018h 'Query Stat Data Types'
f 07Jun13 21:46:03.906: <MCE> C WMD: Workstation Command: h=00 0018h 'Query Stat Data Types'
f 07Jun13 21:46:04.031: <MCE> C WMD: Workstation Command: h=00 0515h 'Qry Prmpt Inf'
f 07Jun13 21:46:04.078: <MCE> C WMD: Workstation Command: h=00 000Eh 'Qry Config'
f 07Jun13 21:46:04.140: <MCE> C WMD: Workstation Command: h=00 0517h 'Qry Prmpt Err'
f 07Jun13 21:46:04.265: <MCE> C WMD: Workstation Command: h=00 0011h 'Flush Start'
f 07Jun13 21:46:04.265: <MCE> C MIC: Flush being started
f 07Jun13 21:46:04.265: <MCE> **** Suspended: 35780
f 07Jun13 21:46:04.281: <MCE> [Product:System Presence Fault: Satellite board 24 volt presence (SAT_&24V+) Not Detected]
f 07Jun13 21:46:04.281: <MCE> Use 'Resume' to continue!
f 07Jun13 21:46:04.484: <MCE> C WMD: Workstation Command: h=00 0515h 'Qry Prmpt Inf'
f 07Jun13 21:46:04.546: <MCE> C WMD: Workstation Command: h=00 0517h 'Qry Prmpt Err'
f 07Jun13 21:46:04.609: <MCE> C WMD: Workstation Command: h=00 0515h 'Qry Prmpt Inf'
f 07Jun13 21:46:04.656: <MCE> C WMD: Workstation Command: h=00 0517h 'Qry Prmpt Err'
Yes we have done reset button task and also we have checked all power supplies which are working fine not any change after reset
Hi, what is the PDB's firmware version?
If it is below 1.48 try to knock the relays on board - maybe the contacts sticked together ?
Are PS 2 & PS 3 on while covers closed?
Check with "system" for air supply.
Check with safety service key if problem gone ( no image possible).
You may try also:
>>sio con 10
Connecting to Remote Board Id: 0012 (use ^Z or Esc to exit)
Press [ENTER]. The PDB prompt should appear: PDB>
Enter the 'sat relays' command to check the relays on the PDB:
sat relays
PDB>sat relays
Relay Set K10+K11 is OK
Relay Set K5+K8 is OK
Relay Set K7+K4 is BAD
Relay Set K6+K9 is OK
Relay Set K3+K2 is OK
Post results.
LoWang
Dear LoWang,
I have try to enter but it gave following error,
[MCE] sio con 10
f 11Jun13 17:53:02.453: <MCE> TS>> sio con 10
f 11Jun13 17:53:02.593: <MCE> Connecting to Remote Board Id: 0010 (use ^Z or Esc to exit)SCON Board Id: 0010 is not responding. Operation cancelled.
f 11Jun13 17:53:02.593: <MCE> *** Command Failed: 255
f 11Jun13 17:53:02.593: <MCE> [error description not found]
today during diagnostic, engine behave crazy, sudenly relays spark and machine comes in ready mode but after few minutes it showed a message on serviceshall "f 11Jun13 18:06:17.656: <MCE> C PRD: Power supplies going off!" and engine went off again. about four or five time this symptoms was happened and machine comes online and when we restart the machine it went on error mode and after some times it come online, also i have notice that all the time when machine in error mode and we run command "Door" we found error "<MCE> [Product:Front panel is open, check front panel]". we have check the door wires and locks are seems ok.
Adrian, in your case, the Power Distribution Board (PDB) is not seen by the MCE. This is why your >>sio con 10 fails. This is usually caused by a firmware error on the PDB, bad CAN cable or bad PDB.
"[PST:No response received from Power Distribution Board]"
Your safety loop shows open because PDB controls it and it does not report the status to the MCE board.
A stuck relay that LoWang is suggesting is not related to this behavior.
Usually pressing the blue reset button works but you have to press it with the power on.
Turn power on - wait 2-3 minutes - watch the color of the PDB lights - some will be red - press the reset button shortly - the lights will flicker - you may hear the relays also clicking on/off - if this is successful, the lights will turn green if there are no other problems and doors are closed (power box panel is not monitored).
The power supplies are most probably good since the MCE boots up.
Your last post indicates the PDB eventually came up at some point - otherwise the relays would not click.
If it stays in ready status for long enough try to reload the firmware on the PDB (files should be in the creo\controlledrelease folder)
Nemo, The problem is that machine didnt give me a time to restore PDB firmware, it went restart in about few minutes and some times run bit long but we can not restore in this situation..
Disconnect all cables from PDB except power supplies and J13, J14 (CAN bus and terminator). Ignore the errors and see if the board is stable - if it is, try loading PDB firmware. If it keeps resetting with cables disconnected most likely you will need a new PDB. The part number is 10-4112L
We have re upload the PDB firmwares but problem remains. only change a little bit behavour that now first time machine boots fine but after few minutes relays fliker and power supplies gets off with error *** Unsolicited Message 35780 Warning [Product:Carriage Presence Fault: Carriage motor presence (CM_&Motor) Not Detected]
please advice.....
Is the PDB stable with cables disconnected from it as I suggested earlier? If not, the board is bad.
If the board is stable you may have a problem in the wiring for the safety loop taking the board down.
please advice.....
Adnan, I'm afraid that your PDB is bad, need replacing one.
Hi Adnan,
I have encounter similar behavior in past. Problem could be related with power supply for security loop. Everything seems to be OK for a period of time and suddenly machine gone crazy. I found that a fan on power supply is stuck and module slowly is heating up until enter in protection mode. Check the fan for PS2. If is not working change the power supply.
CAN terminator
CAN terminator
Adnan, picture for you....
Hi
I have problem in my ctp trendsetter Q400
(this error) : Fatal fault (02318) laser diode :
The laser power could not be calculated during calibratio
please help me
